Hello
I would like to know if all the users added their personal signatures (the signature as been made base on a template). Can I build a view with the user name and a field that can show me the file path of the signature?
Hello
Subject: How to verify if every users add their signatures
Here’s some code I found searching around a while back which you may find helpful…
'Disable signature in users mail profile
Set docProfile = dbMail.GetProfileDocument(“CalendarProfile”)
strProfileEnableSignature = docProfile.EnableSignature(0)
If strProfileEnableSignature = “1” Then
docProfile.EnableSignature = “”
Call docProfile.Save(True,False)
'Re-enable signature in users mail profile
docProfile.EnableSignature = “1”
you’d need to loop through all mail files on your servers and grab the calendar profile doc and extract the info you want.
No,
I think that you will need to scan every mail files (Calendar profile) to check what’s in it,
JYR
