How to use @Left and @right in a name field using Lotus Script
Hi All,
I have a field on a form called Submitted By and that field people type in First Name + Space + Middle Initial(if it has) + space + LastName
I need to extract FirstNAme , MiddleItintial and Lastname using Lotus Script in separate variables.
How can I achieve this using Script
Thanks in advance,
ac ac
Subject: How to use @Left and @right in a name field using Lotus Script
Hi, go to Notes designer help and look for @right and @ left and have a look at Language cross reference section.
Cheers !!
Subject: RE: How to use @Left and @right in a name field using Lotus Script
I tried using the evaluate in Lotus Script but still it doesn’t work …It givee me an error "Error in Evaluate?
Here is the code
Dim str1, str2 As String
Dim Fname, lname, mname as variant
	str1 = doc.SubmittedBy(0)
	Fname =  Evaluate({@Left(SubmittedBy; "")}, doc)
	Lname =  Evaluate({@Right(SubmittedBy; "")}, doc)
	str2 = Lname(0) + " , " + Fname(0)
Please help
Thanks in advance,
ac ac
hi, try this…do the changes in the code per your requirement.
Dim Fname, lname As String
str1 = "Huzefa Haider"
Fname = Strleft( str1, " ")
Msgbox Fname
Lname = Strright( str1, " ")
Msgbox Lname
str2 = Lname + " , " + Fname
Msgbox Str2
Cheers!!
This
will define str1 and Fname as Variant, which will work, of course, but is not intended. For proper typing you have to write:
Dim str1 As String, str2 As String
Dim Fname As String, Lname As String
hi,tweak your existing code a bit … here’s the eg.
Dim str1 As String , str2 As String
Dim Fname As String , lname As String, mname As String
str1 = "Huzefa A Haider"
Msgbox Fname
mname=Strright(Strleft( str1, " ",0,2)," ")
Msgbox mname
Lname = Strright( str1, " ",0,2)
Msgbox Lname
Msgbox Str2
Cheer!!
Thanks Huzefa , it worked !!!
Also what if the user has middle initial, like “XYZ M. ABC”
Thanks,
ac ac
