How to uninstall Domino 9.0.1 Fix Pack 2 Interim Fix 1
Hello
In order to install Domino 9.0.1 Fix Pack 4 I need to uninstall Domino 9.0.1 Fix Pack 2 Interim Fix 1 first. (= re-run the installer of the 901FP2HF358-aix.tar)
Unfortunately I can’t find this fix on Fix Central because it has been re-released under the name 901FP2HF390-aix.tar. Where can I obtain 901FP2HF358-aix.tar?
Thank you!
Regards
Patrice
Subject: An easier approach
You can just reinstall 9.0.1 and then go straight to FP4.
Subject: Does a Domino re-install overwrite Sametime ?
Sametime is also installed. Does it remain intact when I reinstall Domino 9.0.1 ?
Subject: No impact to Sametime
The installed modules are different. Now if you reverted to a different major release of Domino (e.g. 8.5.x), then you could run into a supported configuration issue. But that’s not the case here.
Subject: …and if you really need it…
Just open a pmr and support can give it to you.
