How to switch between databases by using a button
Hi,i have an application which consists of three databases. I want to link them together by using a button which switches between the databases. By clicking on this button the database should open, that´s no problem, but when the database is already open and you click on the button I only want to switch to the the database.
Is there a way to look, whether a database is already open? And is there a method which switches between the specified databases like using CTRL and TAB?
thanks Johannes
Subject: how to switch between databases by using a button…
  1. Create 3 button on page/form
[Button1]
@Command([CloseWindow]);
@Command([FileOpenDatabase]; “-ur server-”: “-ur db1.nsf-”);
[Button2]
@Command([FileOpenDatabase]; “-ur server-”: “-ur db2.nsf-”);
[Button3]
@Command([FileOpenDatabase]; “-ur server-”: “-ur db3.nsf-”);
This code will close the current active window, and open the desired db (so called switch between DB).
hope it can help u.
Subject: RE: how to switch between databases by using a button…
hi, thanks for the code.the first way I tried to switch between the db’s was this way, but it only works, when I put “posted” between the “@” and “Command” - like @PostedCommand([FileOpenDatabase]; “-ur server-”: “-ur db2.nsf-”)
