How to run agent in lotus script using evaluate function
sarangan
sarangan
Subject: How to run agent in lotus script using evaluate function
See the Help file and example.
Is there a specific code example you are having trouble with?
Subject: RE: How to run agent in lotus script using evaluate function
Sir
Thanks for your reply
In help file there is no example.
My question is
result=Evaluate(@command[runagent];“Agentname”))
it is correct code or not. if it wrong then please write me to what are the steps for run the agent in lotus script. I try many type of ways,nothing to work. Even i search in web,there is no code available in web.
reply me
HiYou cannot evaluate Commands
You can use the NotesAgent object, and the notesAgent.Run method in script.
It’s all in the help files.
HTH
Ben
Sir
I using this notesagent object,But it not working correctly.If you having the code please mail to me
bye
Sarangan
Sarangan,
Post your code here, and we’ll try and work out where you’re going wrong.
Ben
Sir,
I give the example code for my problem.This code working correctly my main code will work perfectly.
The example code is:
In a view action button click event code
Sub Click(Source As Button)
Dim s As New NotesSession
Dim db As NotesDatabase
Dim agent As NotesAgent
Set db = s.CurrentDatabase
Set agent = db.GetAgent("test") 'Test is the agent name
If agent.Run = 0 Then
Messagebox "Agent ran",, "Success"
Else
Messagebox "Agent did not run",, "Failure"
My agent code : “Test”
Sub Initialize
Msgbox "Test the agent"
I click the action button,the msgbox not display,but an error is display. The error is
Unsupported trigger and search in the background or embedded agent.
I run the agent using formula command runagent event the msgbox display correctly.
How i rectify this error.
reply me
Thanks for ur previous reply
Sarangan
Sarangan,
The problem lies with your agent, not the code launching it.
The error means that the agent’s usual trigger (from actions menu, against selected documents) is not supported when it is called as a back-end agent.
Change the agent to run Manually from Agent List and make sure the agent is not set to run against “selected documents”.
Good Luck
Ben
Sir,
I make the respective change and the agent run correctly.
bye
Sarangan
Sir
Then How to run agent in lotus script.
My problem is :
I have a button in view. In button click event i run an agent. How it is possible to run. If any code available please mail to me.
bye
Sarangan
If you just want to run an agent, then use the Simple Action option to run an agent in your view action. Otherwise, see my other post.
