How to read script %INCLUDE "c:\xxx\zzz.lss"
I need change some lotus script in db. however, in the script there is only this text:%INCLUDE “c:\xxx\zzz.lss” (is it possible to find out the script somewhere and change it? I do not understand that line… thank you, jakub
Subject: how to read script %INCLUDE “c:\xxx\zzz.lss”
That means that the script isn’t located in the database, but is a separate file on the system. Open the file zzz.lss located in the path c:\xxx\ and You will find the script that has been included.
hth
