I have two numbers fields. In those fields I put to numbers. I’d like to have result , five randomize numbers in five fields.
for example:
in field 1 we put= 1
in field 2 we put= 250
result should get 5 rendomized numbers : 45, 100, 2, 203, 176
result couldn’t be <1 and > 250!
Subject: How to randomize between two numbers?
thanks
From the Domino Designer Help:
To generate a random number between any two numbers x and y, use the formula
( y - x )*@Random + x
hcl-bot
4
Subject: be careful - this may result in X or Y!
@Random CAN return 0 or 1 - not likely but then you would get numbers your original post excluded
In addition this will be fractional numbers
you may need and @Integer or @Round.
and there is also a small change that the same number will be generated twice.
(More like with @Integer and a small range of course)
if you need five unique numbers then you have more work to do.
