How to prevent Domino web engine from adding the carriage return symbol while converting notes document to HTML
I want to pass the text string to another application via http. To do that i made a special form that is beeing computing “on the fly” while form is open. It has only one text field that contains text string.But when Domino converts this form to HTML it adds the carriage return symbol at the end of that text string.
Does someone know how to prevent Domino from doing that?
Subject: How to prevent Domino web engine from adding the carriage return symbol while converting notes document to HTML
Try selecting the relevant parts of the form and mark as ‘pass-thru HTML’. Select the lines above and below as well.
This usually does the trick.
