How to get max value in a multiple values field by using lotus script
Hi, everyone:
Does anybody know how to get the max value from the multiple values field by using lotus script in an agent? Any help I appreciate!!!
Subject: ubound
Subject: how to get max value in a multiple values field by using lotus script
NotesItem.Values is an array of values. The type of array depends on the datatype of NotesItem. You can use Forall to iterate over this array to find the biggest one. If your Notesitem is numeric, something like thisBiggestSoFar# = 0
Forall v in item.Values
if v > BiggestSoFar# then BiggestSoFar# = v
End Forall
Subject: RE: how to get max value in a multiple values field by using lotus script
Hi, Bob:I appreciate your help!!!
With that code you’d wind up with zero (and a lie for a result) if all your values were negatvie. Better would be to initialize BiggestSoFar to item.Values(0) then run your forall loop. :slight_smile:
Thanks Jeremiah!I appreciate your help!
