How to get first and second highest totals in a simple way?
Hello,
I have got the totals like
Total1 = 10
Total2 = 20
Total3 = 5
Total4 = 10
Total5 = 15
Total6 = 5
Using the script how can evaluate which is the first highest number and the second highest number?
I would like to get only two numbers.
In this case I would like to get only Total2(first highest) and the Total5(second highest.)
Can someone help me?
sri
Subject: How to get first and second highest totals in a simple way?
Hello,
I am not sure in which script (javascript or lotusscript) you are expecting the solution. but i hope the following steps give an idea…
  1. First take all the values in array.
  2. Remove duplicates
  3. Sort the array with remaining values
  4. you can pick first and second highest values with the index.
Thanks,
Sreedhar
Subject: RE: How to get first and second highest totals in a simple way?
use max & min function to get the highest and least values
Hi Sridhar,
Thanks for the response. i am using lotusscript.
Sri
Hello,
Here is the code which satisfies your requirements…must say thanks to Richards as half of the code from his post.
Dim srcList(1 To 10) As Integer
Dim destList As Variant
srcList(1)=10
srcList(2)=20
srcList(3)=5
srcList(4)=10
srcList(5)=15
srcList(6)=5
destList=Arrayunique(srcList)
V1 = -999
V2 = -999
Forall x In destList
	If x > V1 Then
		V2 = V1
		V1 = x
	Elseif  x > V2 Then
		V2 = x
End Forall
Msgbox v1
Msgbox v2
Sreedhar
There’s no need to sort the values. It would be quicker to do a one-pass evaluation of the elements.
Something like …
V1 = -999
V2 = -999
For all x in values-to-be-examined
if x > V1 then
V2 = V1
V1 = x
else if x > V2
V2 = x
end if
Next x
V1 will have the largest value, and V2 will have the next largest. If you want to ignore duplicates, then you’ll need additional tests.
Hi richard,
Thanks for the post. here you are comparing only two values. I need to compare 8 values and get the first and second largest values?
How can i do this? please let me know.
sri
Look again. He’s suggesting a one-pass loop through all your values.
