How to do ... using Events4.nsf
Good Day
Using Events Handler, how can i moinitor:
  • Full Administration Access
  • Any admin commands on notes server or console
  • Create/Delete new mail DB by admin
  • modify any entry in the NAB
  • openning same mail DB from from two location at same time
Thanks and Regards
Subject: How to do … using Events4.nsf
How to receive notification when users enable ‘Full Access Administration’ mode
http://www-1.ibm.com/support/docview.wss?uid=swg21197579
Subject: RE: How to do … using Events4.nsf
you can monitor create/delete of mail files the same way: ie. by setting up an event handler to match the text “created by” and “deleted by”.
