How to do muliple lookups using Ajax?
Hi, I am new to ajax and in in one of my web projects I have four combo boxes which have to be lookup using ajax.Could any one suggest me how to fulfill this requirement. Any help would be appreciable. Thank you.
Subject: How to do muliple lookups using Ajax ?
you can use lookups like this in ajax
var req;
var strField;
var lkpKey;
var sType; // 1 - combo box , 2 - text multiple value
var Col; // used for column selection in a view
function dbLookup(server,path,view,key,column,Name, xType,protocols)
	sType = xType;
	lkpKey=key;
	col = column;
	strField=Name //Put your second combo name here to get dblookup result
	var pos=0;
	currURL = (document.location.href).toLowerCase();
// alert(currURL);
	if (server == "")
		pos = currURL.indexOf('://');
		if (pos < 0 )
				server = server  // Put your server name here
	else
			pos += 3;
			pos = currURL.indexOf('/', pos);
			server = currURL.substring(0, pos)
// Check if path is empty
	if (path == "" )
			if( pos > 0 )
					newPos = currURL.indexOf('.nsf',pos);
					if (newPos > 0)
							path = currURL.substring(pos+1,newPos+4)
//Check if column is empty
	if( column !="" )
			column -= 1;
			vurl = protocols +  path +"/" + view +"?Readviewentries&restricttocategory="+lkpKey
			//checking whether browser is mozila or Netscape
			if (window.XMLHttpRequest) // Mozilla.. SaFari...
				req = new XMLHttpRequest();
				 if (req.overrideMimeType)
						req.overrideMimeType('text/xml');
					req.onreadystatechange = processReqChange_lookup;
					req.open("GET", vurl , true);
					req.send(null);
			else if (window.ActiveXObject) 	//checking whether browser is IE
					req = new ActiveXObject("Microsoft.XMLHTTP");
					if (req)
							req.open("GET", vurl, true);
							req.send();
or look at this link for other reference
http://www.openntf.org/projects/codebin/codebin.nsf/CodeByDate/0D95F1B6946D706D8625705F0049AB59
http://searchdomino.techtarget.com/tip/0,289483,sid4_gci1126394,00.html?track=Ajax_FG
Subject: RE: How to do muliple lookups using Ajax ?
If you use a global “req” variable and you try to do mulitple lookups asynchronously, you’re probably going to have problems. To understand why, I suggest you see my article here:
 http://www.rhs.com/web/blog/poweroftheschwartz.nsf/d6plinks/RSCZ-6CDPEX
And the follow-up here:
http://www.rhs.com/web/blog/poweroftheschwartz.nsf/d6plinks/RSCZ-6CEQAR
Now, I’m sure there are better (and cooler) ways to code safe AJAX than what I put together in my code samples, but the key point is that if you want to do true multi-threaded asynch coding you’d better have a unique XmlHttpRequest object for each request, stored in a variable that isn’t going to be overwritten or go out of scope before the request is fully processed!
-rich
Subject: Multiple lookups is not working
Thanks for your help, but I got one problem. I have used your code and lookup is working fine for the first field.When I try to use it for the second field it fails and prompts error. Colud you please tell me how to use the same code for muliple fields to lookup.
