Can someone please tell me if there is a way to disable using ‘double click’ to put a document into edit mode. I only want the user to be able to use the Edit Button.
Regards,
Marion
Regards,
Marion
Subject: Link to response in old forum
Hi, sometimes a search in an older forum turns up an answer that doesn’t show in the newer ones.
See below for discussion of precisely what you’re trying to do.
Hope this helps,
Phil
