How to create auto incrementing number
How to create auto incrementing number? Please anyone help me.
Subject: in Notes FAQ
Subject: How to create auto incrementing number
Hi, Its Very Simple. U Create a View Which Will Store a value “1”.
and write a agent which will take the value from the view (Colum) and Update the value and save it in same location.
Like That
Dim s As New NotesSession
Dim db As NotesDatabase
Dim view As NotesView
Dim doc, docv,uDoc ,docv1 As NotesDocument
Dim num As Variant
Dim n ,mail As Variant
Dim nd As String
Set db = s.CurrentDatabase
Set uDoc = s.DocumentContext
Call uDoc.save(True,True)
Set view = db.GetView(“Vserialnumber”)
Set docv = view.GetFirstdocument
If Not docv Is Nothing Then
n = docv.GetItemValue(“MSNO”)
num =Cint(n(0))+1
uDoc.CompNo=n
docv.MSNO=num
Call docv.save(True,True)
Pawan Kumar
