How to compare dates? Help
Hi…
I am trying to create a lotusScript agent that will retreive all the documents from a view and compare dates to put a flag to either "1" or "0". my problem occures when I try to check that now >= doc.date1 & now <= doc.date2 . What is the proper way to verify that the current date is within the start and end dates of the document?
Thanks, Bryce!
Subject: how to compare dates? Help…
Use the NotesDateTime class.
Method TimeDifference.
Set hdItem=doc.Getfirstitem(“Date1”)Set hddatetime=hdItem.DateTimeValue
Set hdItem2=doc.Getfirstitem(“Date2”)
Set hddatetime2=hdItem2.DateTimeValue
Set DateTime = New NotesDateTime( “Today” )
x= DateTime.TimeDifference(hdDateTime )/(86400*365)
y= DateTime.TimeDifference(hdDateTime2 )/(86400*365)
if x > 0 and y < 0 then…
Is that helpful?
At the very least:
now >= doc.date1(0)
