How does Cluster Replication work with Transaction Logging?
According to the Admin Guide when Transaction Logging (TL) is used there are 3 components: DB in the memory (always up-to-date), TL log file and DB on disk.
Transaction logging posts all the database transactions to the log file, without waiting for the transaction to commit to disk. After being posted to the log file, the change is considered successful. The physical write process can wait until the server is less busy or occur at periodic intervals. The changes are written to disk in a batch.
What happens between the time when the transaction is posted to the log file and when the database is updated on the disk? Databases are cached in memory while they are open. The writes to the database happen to the in-memory copy of the database. They are then immediately sent to the transaction logs. Later, the memory-cached version of the database is posted to disk, updating the databases. Since the transaction log is sequential, there is no seek time, and only enough information is written to the logs to redo (or undo if necessary) the operation. In many cases, this is less information than the database write to disk.
If the database is not yet completely written to disk and you open it, you are opening the memory-cached version. If the server crashes before the version on disk has been updated with the changes, restarting the server applies the logs to the database during restart.
How does Cluster Replication work with TL? What does ClRep replicate?
Subject: TLing is per-server
Cluster Replication does not replicate any Transaction logging related data between Servers.
Subject: What if the primary server crashed?
Does it mean that if1) a primary server crashed befare changes were commited on the primary server to the nsf file AND
  1. users were failed over to the standby one
they will not have up-to-date database until the primary server recovers and updated from TL logs nsf db is replicated to the standby server?
Subject: Correct
Correct
