How do i disable right click
How do i disable right click.
I’ve created an Outline entry on which i don’t want right click to work. So how do i disable the right click action. (Any sample code?)
I’ve gone through all the earlier posts, then I found that “When I unchecked Create personal folder/views the right click action was disabled on my mail box. (6.5)” but i tried to find out “Create Personal Folder/Views” but couldn’t able to.
Could you please help me out??
Thanks,
Vinod.
