HiI have the following code that dumps values into one field…ie. you select a family, it then displays related companies and then related mandates, at the moment it dumps the values into one field. I would like to dump each company selected into a seperate field as well as mandates…there could be up to 7 companies linked to a family with the equal amount of mandates??
Any advice appreciated.
Thanks in advance, see code below:
Sub Selections (doc As NotesDocument)
Dim w As New NotesUIWorkspace
Dim s As New NotesSession
Dim AddView As NotesView
Dim DbPath As String
Dim ServerName As String
Dim ProductType As String
Dim Adoc As NotesDocument
Dim Bdoc As NotesDocument
Dim Cdoc As NotesDocument
Dim db As NotesDatabase
Dim TempAddress As String
Dim TempAddress2 As String
Dim uidoc As notesuidocument
Dim PickCollection1 As NotesDocumentCollection
Dim PickCollection2 As NotesDocumentCollection
Dim PickCollection3 As NotesDocumentCollection
Dim ProfileDoc As NotesDocument
Dim IENLeadsEnabled
Dim tempstring As String
Dim tempstring1 As String
Set db = s.CurrentDatabase
Set ProfileDoc = ExtensionsProfile(db)
IENLeadsEnabled = ProfileDoc.IENLeadsEnabled(0)
Dim IENAddressesDbFound As Variant
Call IENGetProfilePathFrontEnd(ServerName, DbPath, IENAddressesDbFound)
If IENAddressesDbFound = False Then Exit Sub
Dim AddDb As New NotesDatabase(ServerName,DBPath + "IENAddresses.nsf")
Dim ItemDb As New NotesDatabase(ServerName,DBPath + "IENItems.nsf")
Dim OrgView As NotesView
Dim OrgColl As NotesDocumentCollection
'get list of client families
pText = "Select Client Family"
wTitle = "Select"
Set PickCollection1 = w.PickListCollection(PICKLIST_CUSTOM, False , ServerName, DBPath + "IENAddresses", "(ClientFamilies)", wTitle, pText)
Set Adoc = PickCollection1.GetFirstDocument
If Not (Adoc Is Nothing) Then
'tempstring = ""
'get list of companies under client family
'tempstring = doc.IENCompany(0)
'doc.IENCompany = tempstring + adoc.IENCompany(0)
'doc.IENAssOrg = "Yes"
'Call doc.save(False,False)
Set OrgView=AddDb.GetView("(Parent)")
Set OrgColl=OrgView.GetAlldocumentsByKey(Adoc.IENCompanyDocumentUniqueID(0),True)
If OrgColl.count>0 Then
pText = "Select Companies within "
wTitle = "Select"
Set PickCollection2 = w.PickListCollection(PICKLIST_CUSTOM, True , ServerName, DBPath + "IENAddresses", "(Parent)", wTitle, pText + adoc.CompanyName(0),Adoc.IENCompanyDocumentUniqueID(0))
Set bdoc = pickcollection2.GetFirstDocument
Do While Not (Bdoc Is Nothing)
tempstring = ""
'run through companies and get their mandates one company at a time
tempstring = doc.FamilyCompanies(0)
doc.FamilyCompanies = tempstring + "; " + bdoc.ienviewfullname(0)
Call doc.save(False, False)
Set OrgView=ItemDb.GetView("(OrgMandate)")
Set OrgColl=OrgView.GetAlldocumentsByKey(bdoc.IENCompanyDocumentUniqueID(0),True)
pText = "Select Mandates of "
wTitle = "Select"
Set PickCollection3 = w.PickListCollection(PICKLIST_CUSTOM, True , ServerName, DBPath + "IENItems", "(OrgMandate)", wTitle, pText + bdoc.CompanyName(0),bdoc.IENCompanyDocumentUniqueID(0))
Set cdoc = pickcollection3.GetFirstDocument
Do While Not (cdoc Is Nothing)
tempstring = ""
'*****each mandate can be worked on here
tempstring = doc.CompanyMandates(0)
doc.CompanyMandates = tempstring + " " + cdoc.ienprojectdescription(0) + " " + cdoc.ienprojectnumber(0)
Call doc.Save(False,False)
Set cdoc = pickcollection3.GetnextDocument(cdoc)
Loop
Set Bdoc = pickcollection2.GetNextDocument(bdoc)
Loop
Set adoc = pickcollection1.GetNextDocument(adoc)
