I have searched the forum and found many simliar problems with the Hide When formula however I think I have more of a logic problem than a bug.
I am working on hiding a action in the inbox folder from certein users based on the OU structure. Attached is my code:
@Name([HierarchyOnly];@UserName) =
(UNA/AMERICAS/ACME |
UNB/AMERICAS/ACME |
UNC/AMERICAS/ACME |
UNM/AMERICAS/ACME)
The code works fine when I have only one entry:
(UNA/AMERICAS/ACME)
however when I add the second/third/ec… the code breaks and gives me a eror of incorrect operator, number expected.
What am I doing wrong?
TIA
Subject: Hide When formula problem
I don’t know if this will help, but I’ve overcome similar problems in the past by repeating more lines of code than you’d like to. Try this:
@Name([HierarchyOnly];@UserName)=UNA/AMERICAS/ACME |
@Name([HierarchyOnly];@UserName)=UNB/AMERICAS/ACME |
@Name([HierarchyOnly];@UserName)=UNC/AMERICAS/ACME |
@Name([HierarchyOnly];@UserName)=UNM/AMERICAS/ACME
Like I said, it might be wrong, but give it a go!
Subject: RE: Hide When formula problem
Thank you for your help. I was able to resolve this issue by using:@Name([OU2];@UserName)=“UNA” : “UNB” : “UNC” : “UNS”
Subject: Use ":"s instead of "|"s and add ""s around the names…
@Name([HierarchyOnly];@UserName) = “UNA/AMERICAS/ACME” : “UNB/AMERICAS/ACME” : “UNC/AMERICAS/ACME” : “UNM/AMERICAS/ACME”
Subject: RE: Use ":"s instead of "|"s and add ""s around the names…
I’m pretty sure the literal value is actually “OU=UNA/OU=Americas/O=ACME”.
Subject: So then this would work…
@Name([OU2];@UserName) = “UNA” : “UNB” : “UNC” : “UNM”
