Hide databasedesign makes problem with webqueryopenagent
Hy folks,I have developed an application for notes and the web. For some security reasons, I want to hide database design (cause I want to add some code to the database open event for registration reasons - registration key entering - lookup the key on a public server - gain access to the user or close database).
The registration lookup works very fine. I want to hide database design for security reasons. But if I hide the database design, some functions don’ t work properly.
I tested this with 2 copies of the application:
In the first database, some functions from a script library are not found and the user got n error in the notesclient.
In the second try, everything worked fine in the notesclient but in the web, my webqueryopen-agents didn’ t work properly. I use functions from the script library there as well. In the servers log-file, there wasn’ t any errors regarding to my agent.
Is this a known bug with the script libraries???
I did following:
  1. Create a new copy of my database, rename it to extension *.ntf.
  2. Set databaseproperties (database is a template…)
  3. Create a new database, select my template from step 1, 2 and check “hide formulas and lotus script”.
Any suggestions /answers? Maybe another product / addon?
Thx,
Ayhan
