Help with @subset
I wanted to list a set of strings in each line of a text field however, i always get the "; " string. how can i omit this?
sample set (taken using dblookup):
10; 11; 12; 13
i tried using for loop to display each string on a field at different lines but instead i got this:
10
; 11
; 12
; 13
what code shall i use to display the results without the "; "? Thanks!
Subject: Help with @subset
can you tell me your code .I guess i can help you
Subject: RE: Help with @subset
scrap my previous post… anyway, here’s my code
tmp_person:=@DbLookup(“”:“NoCache”;ictserver:ictdatabase;ictview;tmp_id;5);
tmp_person now has lists of values, namely:
Kevin; Donald; Gwen; Todd
then i used this code to display them on a text field, each on a new line…
FIELD ICT_PER:=tmp_person + @NewLine
however, field displays:
Kevin
; Donald
; Gwen
; Todd
I wanted to omit the "; "… I am kinda new with this thing, so i don’t have idea yet.
Thanks!
  1. remove the @newline from the line of code:FIELD ICT_PER:=tmp_person;
  2. Make the field ICT_PER multivalue (1st tab field properties, select “Allow multiple values”)
  3. On the 3rd tab of the field properties, at “Display seperate values with” select “New Line”
If you want to keep the value ICT_PER as one string (so not multivalue) you can use:
FIELD ICT_PER:= @implode(tmp_person;@NewLine)
Regards,
René
yep already got it. hehe thanks for the response! i already did modify the values in the tabs, but i prefer the implode command. thanks!!!
Try this… I have not checked this. I guess it will help you out.
@Explode(string ; separators) Converts a text string into a text list; the second parameter specifies the separators (except newlines) for elements in the string.
