Hi there,
I’m new to script, like this is my first attempt!. What I want to do is to read in a subject line from a mail (no problem so far this works)
subj = doc.getitemvalue ( “Subject” )
Messagebox ( subj ( 0 ) )
then I need to split subj into three components. Layout of subject is “Survey for steve.gardner@domain.com (00011117) Ref: This is a short description”
Doing this in formula I would :
tmpName := @Middle(subject; “for “;” (”);
tmpNo := @Middle(subject; “(” ; “)” );
tmpRef := @Right(subject; “:” )
I then want to populate fields with these values I guess by using
Call doc.ReplaceItemValue(“Name”, tmpName)
Its that chopping of the subject line that I can’t get my head around at the moment!
Any help welcomed …
Subject: Help with sting handling in Lotus Script
You would want to use the left, mid, or right LS functions.
Check the designer help db.
mid statement example
Dim string1 As String, string2 As String
string1$ = “ABCDEF”
string2$ = “12345”
’ Replace the characters “BCD” in string1
’ with the characters “123” in string2.
Mid$(string1$, 2, 3) = string2$
Print string1$ ’ Output: A123EF
The replaceitemvalue method looks right to me.
Hope that helps.
Subject: RE: Help with sting handling in Lotus Script
Thanks.Needs to be slightly more complex as the length of name varies but on the right track
x = position of “(”
y = position of “)”
r = position of “:”
l = Len ( Subject )
tmpname = Mid$ ( subject, 13, x -13)
tmpNo = Mid$ ( subject, x, 9)
tmpRef = Right$ ( Subject, l - r)
That should do it ?
Now all I have to do is code using InStr ?
or am I over complicationg this
Subject: Easiest way is to use Evaluate…
tmpName = Evaluate(|@Middle(subject; “for “;” (”)|, doc)tmpNo = Evaluate(|@Middle(subject; “(” ; “)” )|, doc)
tmpRef = Evaluate(|@Right(subject; “:” )|, doc)
Steve,
Considering you want to split the string I would suggest you look
at the spilt function. It does everything you want and is easy
to use. Check out the designer help for documentation.
By the way I would not use the Evaluate method when there
are many native LotusScript functions that will do the job
for you.
Example:
Dim strSubject As String
Dim varSubject As Variant
Dim strName As String
Dim strNo As String
Dim strRef As String
strSubject = Cstr(doc.GetFirstItem(“Subject”).Values(0))
varSubject = Split(strSubject, " ", 4, 5)
strName = varSubject(2)
strNo = varSubject(3)
strRef = varSubject(4)
Regards,
Anthony Lee
look at left, mid, and right in the help file. Lots of examples there
