Hi
I’m a newbie when it comes to script. I got help with a script to create an e-mail for the docs library, it works great. Now I just need to find a away to not send the doc and to be able to pick the address for the e-mail and not have it coded in the script. The reviewer thing doesn’t work for my users cause they don’t like that is creates a “copy” of the orginal document and then a response from everyone etc. They just want to notify certain people when a doc has been put in the library. Here is the current script.
The following replaces the existing code in the Declarations section of Globals for the Document form
Dim FormW As NotesUIWorkspace
Dim FormDoc As NotesUIDocument
%INCLUDE “lsconst.lss”
The code below replaces the existing code in the Queryclose event of the Document form
Sub Queryclose(Source As Notesuidocument, Continue As Variant)
Dim rtitem As Variant
Dim db As NotesDatabase
Dim doc As notesdocument
Set doc = source.Document
If Source.EditMode Then
Dim answer As Long
answer = Messagebox ("Do you want to send notification to reviewers that this doc has been updated?", MB_YESNO,"")
If ( answer = IDYES )Then
Dim memo As NotesDocument
Dim mailitem As NotesItem
Dim mailrtitem As NotesRichTextItem
Dim docsubject As String
Set mailitem = doc.GetFirstItem( "Subject" )
docsubject = mailitem.Text
Set memo = New NotesDocument( db )
memo.Form = "Memo"
memo.Subject = "The document "+docsubject+" has been updated, please review."
' This sets the form name and subject
memo.Form = "Memo"
' This creates the information in the Body of the mail message
Set mailrtitem = New NotesRichTextItem( memo, "Body" )
Call mailrtitem.AppendText( "Here is a link to the document " )
Call mailrtitem.AppendText( "with the subject : " + docsubject )
Call mailrtitem.AddNewLine(2)
Call mailrtitem.AppendDocLink( note, db.Title )
'This sets the names of the recipients
Dim recipients( 1 To 3 ) As String
recipients( 1 ) = "Kim Larson/Interaction"
recipients( 2 ) = "Kim Larson/Interaction"
recipients( 3 ) = "Kim Larson/Interaction"
Call memo.Send( False, recipients )
If note Is Nothing Then Exit Sub
If Not(note.HasItem("CopyBody")) Then Exit Sub
'we already copied the rest of the document, now we need to copy the body field
Set savenote = db.GetDocumentByUNID(note.OriginalSaved(0))
If note.HasItem("Body") Then
Set rtitem = note.GetFirstItem("Body")
savenote.RemoveItem("Body")
Call rtitem.CopyItemToDocument(savenote, "Body")
savenote.save True, True, True
note.RemoveItem("CopyBody")
The subject of the email is defined by this string, it takes the subject line of the document in “docsubject”
The content of the email includes a link to the document in the Doc Library database
Put the mail addresses for your recipients in the following section, you can make this whatever number of users you wish.
recipients( 1 ) = "user name/company"
recipients( 2 ) = "user name/company"
recipients( 3 ) = "user name/company"
