Help with reading / retrieving from arrays
I have inherited an application that has a button on a form that is supposed to read through a series of fields and if it finds a match, return the value in a matching field.
For X = 1 To Ubound( doc.Technician )
xstring = Trim(Str(x))
If “doc.Group” & xstring & “(0)” = “2” Then
  doc2.Technician(x-1) = "doc.Tech" & xstring & "(0)"
Next
doc and doc2 are dim’ed above this piece of code. I need to get a count from a field and using that index walk through a seperate field, comparing the value to a string. If the string matches, I then need to get the value in a different field using the same index.
Two problems are occuring. The first is that the IF statement is not finding the value “2” even though it is using the string doc.Group1(0) where 1 is the index. The second is that I am not sure how to redim the array if I get more than 1 hit - which is what I have been told is the actual problem.
Any ideas?
Subject: Try:
Redim d2Tech(Ubound(doc.Technician)For x = 1 To Ubound(doc.Technician) + 1 'Make sure you process the last value
xstring = Cstr(x)
iv = doc.GetItemValue(“Group” + xstring)(0)
If iv = “2” Then
  d2Tech(x-1) = doc.GetItemValue("Tech" + xstring)(0)
Next
doc2.Technician = d2Tech
Subject: Array is not your biggest problem here
If “doc.Group” & xstring & “(0)” = “2” Thendoc2.Technician(x-1) = “doc.Tech” & xstring & “(0)”
Try using something like this:
Dim fieldName as string
fieldName = “Group” & xstring
myItem = doc.GetFirstItem(fieldName)
doc2.Technician(x-1) = myItem.Values(0)
Hope this helps.
Jason
Added, this is just to show a way of thinking about the field name issue and to show you that you can’t use doc.Part & “ofAName” & “(0)”
Not complete code. You would check to see if myItem is nothing and that it has a value instead of just referencing (0) blindly as well.
Subject: RE: Array is not your biggest problem here
Illeagal USE of PROPERTY on the doc2.Technician(x-1) = myItem.Values(0) line
Any other ideas?
Subject: Help with reading / retrieving from arrays
Thanks to all for the ideas and code. I got it to work.
I suppose you want to do something like that:
If doc.hasitem(“Group” + xstring) then
If doc.GetFirstItem(“Group” + xstring)(0) = “2” Then
doc2.Technician(x-1) = doc.GetFirstItem(“Group” + xstring)(0)
End if
Next
“doc.Group” means that you are looking for the string “doc.Group” and not the value in doc.Group…
Subject: RE: Help with reading / retrieving from arrays
Close. I rewrote it slightly and now have an issue with the doc2.Technician(x-1) = Item2.text line.
	If doc.hasitem("Group" + xstring) Then
		Set Item = doc.GetFirstItem("Group" + xstring)
		If Item.Text = "2" Then
			Set Item2 = doc.GetFirstItem("Tech" + xstring)
Next
Illegal Use of Property ??
Basically you can’t write to a filed in that way. What you’ll have to do is create an array first and then write the array to the field after the loop:
dim technicianarray(ubound(doc.technician)) as string
//Then instead of the line giving you a problem
technicianarray(x-1) = item2.text
//Then after the loop
do2.Technician = technicianarray
hth
Dan
