Hi, I need a little help with querydocumentdelete. Basically, I want to say that if the document is a certain form, display a message and do not delete the document.
The document is most likely being deleted from an embedded view on a form.
How do you get a handle to the document being deleted with Querydocumentdelete? Since it’s being deleted from a view, I assume I can’t use uidoc, since it isn’t actually open in the UI. What’s the command?
Thanks!
Ben
