Hi all, I am trying to print a view that, when printed, will print with the page number and date in the header and/or footer.
When you go to print, if you choose to print only the selected frame, it adds the page # and date, but it only prints the docs that you can actually see in the current frame. When you go to print the view, it prints all docs in the frame/view, but does not add the page number/date.
Any creative design methods around this problem? I want to be able to print the entire view, with the page # and date. I tried using an embedded view on a form, but it didn’t work. Any other ideas?
Ben
