Help with Notes type-ahead function for recent contacts
Hello,
i have question about type-ahead function in Notes. When i have in recent contacts address like "Leos Suchomel" <leos.suchomel@domain.com> then i can type suchomel... and address is found. Thats ok. But when is saved address like leos.suchomel@domain.com (without full name in quotation marks) i must start serching with leos... to find it.
Is possible set up that i can search even this addresses with typing suchomel...? Is there some parameter or preferences in Notes?
It seems for Notes is e-mail address only one string.
Leoš
Hello Leos,
You can refer below knowledge articles related to type-ahead functionality. May be it will help :
https://support.hcltechsw.com/csm?id=kb_article&sysparm_article=KB0027681
https://support.hcltechsw.com/csm?id=kb_article&sysparm_article=KB0033542
Feel free to write incase of any additional query at this point of time.
Regards, Amar Sinha
The Type-ahead feature searches for the starting few characters in a word. So, if contact address is like "Leos Suchomel" <leos.suchomel@domain.com>, then you can search using either "Leos" or "Suchomel" because both are two different strings in the address.
In case when contact address is like leos.suchomel@domain.com, this address is a single string and can be searched using first few characters. So, you have to type-in first few characters "leos" to find it and can't be searched using "suchomel" which are middle characters in string.
So, the behavior which you are observing is normal and is working as designed.
