I’m working on an application that will allow a user to embed a graphic in a rich text field, and send that graphic in an email via Notes. To do this, I’m currently using a two-step process: converting the contents of the rich-text field to HTML, and then feeding that HTML to the NotesMIMEEntity classes as a stream. For converting to HTML, I’m using an excellent script library found at nsftools.com in a database called “RT2HTML”. In the case of a rich text field with graphics, the graphic is returned as part of a long HTML string. But when feeding this HTML as a stream, I need a way to tell the NotesMIMEEntity to convert the document back to a graphic. Here’s the code I’m using for that part:
Function CreateAndSend (s As NotesSession,msg_text As String,msg_html As String,Recipient As String,Originator As String, Subject As String)
Dim m_doc As New Notesdocument(db_this)
s.ConvertMIME = False
Set stream = s.CreateStream
Set body = m_doc.CreateMIMEEntity
Set header = body.CreateHeader("Content-Type")
Call header.SetHeaderVal("multipart/alternative")
Set header = body.CreateHeader("Subject")
Call header.SetHeaderVal(Subject)
Set header = body.CreateHeader("To")
Call header.SetHeaderVal(Recipient)
Set child2 = body.CreateChildEntity
Call stream.WriteText(msg_text)
Call child2.SetContentFromText(stream,"text/plain;charset=iso-8859-1",ENC_NONE)
Call stream.Close
Set child3 = body.createchildEntity
Call stream.WriteText(msg_html)
Call child3.SetContentFromText(stream,"text/html;charset=iso-8859-1",ENC_NONE)
Call stream.Close
m_doc.Principal = Originator '## the spoofing
Call m_doc.Save(True, True)
s.ConvertMIME = True '## Restore conversion
sending:
m_doc.Send False
Sleep(1) '## to reduce the load on the server, it sleeps for one second between sendings
Exit Function
End Function
Is this done with content type or encoding? As you can see above, I’m currently using “multipart/alternative” content-type and no encoding. I saw in Notes Help how to change the encoding and what values were allowed, but I saw nothing that explained what encoding method was good for what situation.
Could someone here who’s a little more knowledgeable about MIME help me out, or point me to a good resource where I can find out more about this?
Thanks in advance.
