Help with @mainsend
I need help with this.
Here is what I want the button to do when the user clicks on it:
  1. Save the document.
  2. Send an email to 3 three people, then bcc the other 2 people.
  3. Lastly, a message should pop up saying the document has been saved and emails have been sent to the following people ( It should show thelist ). Click ok.
@Command([FileSave]);
subject:=“New Request - Test Database”;
body:="A New document has been entered into the Test Database. It requires your attention. Click on this link to view → ";
@If(location = “certaincity”;@MailSend(“user1”:“user2”:“user3”;“bcccuser4”;“bccuser5”;“”;“”;subject;“”;body;[IncludeDoclink); “”);
list:=@Unique(“user1”:“user2”:“user3”;“bccuser4”:“bccuser5”);
@Prompt([ok];@DbTitle;“Thank You! Your new document has been saved and mail notifications have been sent to : " + @Implode(list;”,") )
Subject: two revisions …
Change your mailsend function to this:@MailSend(“user1”:“user2”:“user3”;“”; “bcccuser4”:“bccuser5”;“”;subject;body;“”;[IncludeDoclink)
The way you had it, your bcc’s were in the place for cc’s, you had an extra semi-colon, and your body variable was in the slot reserved for document fields to include.
Also change the semi-colon in your @Unique to a colon.
Subject: RE: two revisions …
Ok, here it is, correct?
@If(location = “certaincity”;@MailSend(“user1”:“user2”:“user3”;“”; “bcccuser4”:“bccuser5”;“”;subject;body;“”;[IncludeDoclink)
list:=@Unique(“user1”:“user2”:“user3”:“bccuser4”:“bccuser5”);
