I’m writing an article on the powerful solutions that can be achieved using the Notes C API toolkit.
Instead of using a trivial problem as the basis for the article, I would prefer to base it on a real problem/solution. That would obviously make for more interesting reading.
So, if you have ever had a requirement for a standalone utility program, a custom server task, an export to a particular file format, etc, then please let me know, either by replying to this topic or by emailing me direct at tmccann@btclick.com
I’m looking for something small but not too trivial - and something that would be genuinely useful to yourself and to others. If I get a good idea, I will post the solution here after the article is written. Thanks for your attention and for your ideas.
(This was also posted on the Domino 4/5 forum)
