hcl-bot
February 23, 2005, 10:52am
1
Hi there!
I can’t seem to get the syntax right for my Evaluate method. I’m using @URLEncode to pass a variable through a URL and now I’m trying to use @URLDecode in a lotusscript agent to switch it back.
Dim webDoc As NotesDocument
Dim Desc as String
Dim DescConverted as Variant
Set webDoc = session.DocumentContext
Desc = Strleft(Strright(webdoc.Query_String(0),“&Desc=”),“&Name=”)
DescConverted = Evaluate({@URLDecode (“Domino”;“} & Desc & {”)},webDoc)
What is the correct syntax? I’ve seen different posts on this subject and tried a couple of them, but nothing works.
Gérald
hcl-bot
February 23, 2005, 11:11am
2
Subject: Help with LotusScript Evaluate method.
I don’t believe that the token (webdoc) is required for this use. I also prefer pipes to curly braces, but that is just preference.
coult be
escConverted = Evaluate(|@URLDecode(“Domino”;“| & Desc & |”)|)
hcl-bot
February 23, 2005, 12:47pm
3
Subject: RE: Help with LotusScript Evaluate method.
Couple samples that work
Dim eval as Variant
eval = Evaluate(“@DbLookup (“class”:“NoCache”;“db”;“view”;“key”;“field”)”,doc)
also
Set Doc = collection.GetNthDocument(a)
eval = Evaluate("@Replace (Companies ; ""Citibank"" ; ""Citibank N.A."" ) " , doc )
Call doc.ReplaceItemValue("Companies", eval)
Call Doc.Save(True, False)
hcl-bot
February 23, 2005, 12:43pm
4
Subject: What is actually returned? “”, @Error , something else?
hcl-bot
February 23, 2005, 11:09am
5
Why not capture both of these values in hidden computed fields so you do not have to worry about evaulating it in script?
hcl-bot
February 23, 2005, 3:30pm
6
Thanks everyone!
With your help, I got it to work. Here is the code:
DescConverted = Evaluate(|@URLDecode(“Domino”;“| + Desc+ |”)|)
Have a great day!
Gérald
