All,
I have a button on a form that works, which allows me to make a folder in a specific location using a field “Directory” as the name of the new folder. I now need to move this button to a view.
I added in some more code to the one that is working trying to get it to work in a view, but so far I haven’t had success.
I have the following code (see bottom) which is giving me a Type Mismatch. I have turned on the debugger but it only tells me the same Type Mismatch. I have viewed other code trying to see what I might be missing or what I might try.
I think the mismatch occurs with the valor statement, but do not know how to fix/change this to determine if that is true.
Sub Click(Source As Button)
Dim db As NotesDatabase
Dim view As NotesView
Dim doc As NotesDocument
Dim valor As Variant
Set session = New NotesSession
Set view = db.GetView( "Admin Assis" )
valor = doc.GetItemValue( "Directory" )
Mkdir "C:\Documents and Settings\terico\My Documents\Test\" + valor
Any help is greatly appreciated.
TIA
Teri
