Hi all.
I need some help with Lotus Script - as I don’t really know much! I’ve managed to piece together the script below by reading through various posts on this forum, and it works great.
The only problem is that I have to put the view name in to the code (Set view = db.getview(“ABC1”)
). I'd like it to always run this from the view that the user is currently in. Can someone please tell me how I can do this? I presume it's something to do with setting uiview, but I don't quite get this part yet...
Thanks!
Alex
Sub Initialize
Dim w As New NotesUIWorkspace
Dim uidoc As NotesUIDocument
Dim response As Variant
Dim results As Variant
Dim cmd As String
Dim db As NotesDatabase
Dim db2 As New NotesDatabase(“myServer”,“Archive\archive”&Trim(response)&“.nsf”)
'this is the name of the 2nd database
Dim view As NotesView
Dim doc As NotesDocument
Dim doc2 As NotesDocument
cmd = {@DbColumn(“”:“NoCache”; “MyDominoDirectoryRepID”; “Case Archives”; 1)}
results = Evaluate(cmd)
response = w.Prompt (PROMPT_OKCANCELLIST, “Select a Case Code”, “Select a Case Code”, results, results)
Set db = session.currentdatabase
If view.name = “” Then Exit Sub
Set doc = view.getfirstdocument 'get the first doc in the folder
'check to make sure 2nd database is open, if not, open it
If Not (db2.isopen) Then
Call db2.open(“myServer”,“Archive\archive”&Trim(response)&“.nsf”)
'Now get the rest of the documents from the folder and move it to the
'other database
Do
Set doc2 = doc.copytodatabase(db2)
Set doc = view.getnextdocument(doc)
Loop While Not (doc Is Nothing)
