I need a problem, I have 2 users who check their mail through domino web access one of them have OS XP and the other one Vista, they have template inotes6, well the problem is, when they want to reply or just give forward, in the area where they can put their message, this specific area appear disabled just with a red “x” in ther corner
It’s important to mention than I can’t modify code or something into the template, I have no permissions, so give me ideas, help!
ok actually, this user have SO windows vista and his internet explorer is version 7, well I’m not sure but I guess vista is not supported by inotes6 right?
by the way thank your for your response evan, I hope you can’t answer me with this new information I’ll appreciate it so much
