I have an application that I’d like to bring online. A few weeks ago the basics run smoothly in the webbrower. Since this week, I always get this error while trying to open a document from a view:
Help with HTTP Web Server: Lotus Notes Exception - Entry not found in index
I wonder why I get this error message. The views, navigation and all other stuff works. The links to the documents seems finde and the UNID of the documents and the weblink match each other.
I still can’t find the reason why I get this message instead of the requested document. In former times I remeber this worked, and I don’t can’t find what make this happen.
I would appreciate any help or suggestions, thanks in advance,
Marco
Subject: Help with: HTTP Web Server: Lotus Notes Exception - Entry not found in index
The fault usually means something is missing, a document or a design object of some sort. While looking thru them remember to look at if they are available for the web and/or has a name/alias conflict with a design object only for Notes.
Good luck. Palle
Subject: RE: Help with: HTTP Web Server: Lotus Notes Exception - Entry not found in index
I can’t find it. If I cut the form out of the database and paste it to an old version I still got the form works and I can see it online.Even if I use the old form from the old version of the application database and paste it into the new one with the problem than it suddenly doesn’t work anymore. All other forms seem to work normally, so there has to be a problem with the form specifcally!?
Greets,
Marco
This error is most probably because of failing lookup. You make a @dblookup in a field and the keyword is missing in the lookup view.Check what fields have @dblookup formula and try to find what value it uses as keyword. You can use “Design Synopsys” to make it easier.
If you can not easily find such field, remove half of the fields from the form, preview form in browser and continue cutting in half until the error dissapears, then you can more easily find the field which causes the problem.
Found the problem, there were some WebQueryOpen und WebQueryClose agents missing.
Greets,
Marco
How did you figure it out?
