Help with FTSearch
Hoping someone will see what I’m doing wrong here. I am having a fundamental problem with FTSearch where the search appears to work (returns expected COUNT = 1 in the collection), when I do a GetFirstDocument, a document is returned but has no values in any of the items. I have tried the FTSearch from the client GUI and it returns the expected form (which DOES have value in many of the ITEMS. Code below - any suggestions appreciated.
’ set up code
Set db_forecast = session.getDatabase(“”,str_forecast_name,str_forecast_name)
If Not db_forecast.IsOpen Then
	Messagebox("Could not open" & str_forecast_name)
	Goto ExitSub
Call db_forecast.Updateftindex(True)
’ ftsearch code
Set dc_forecast = db_forecast.FTSearch(Form = “Forecast” & FWorkNum = str_work_number,0)
Set doc_forecast = dc_forecast.Getfirstdocument()
num_docs = dc_forecast.Count
*** RESULT - num_docs = 1 (as expected), doc_forecast is NOT Nothing - designer variable view shows ITEMS in doc_forecast but all values are null (the actual form returned in the client GUI does, in fact, have values)
Subject: Invalid argument data type and FT query syntax
Syntax:
Set notesDocumentCollection = notesDatabase.FTSearch( query$, maxdocs%, [ sortoptions% ], [ otheroptions% ] )
The first query$ parameter is a string. (also mentioned by Brian)
In addition, the FT query string syntax is incorrect.
You need to add Field keyword or for a field name.
Please refer to the help document for the syntax:
http://www-12.lotus.com/ldd/doc/domino_notes/6.5.1/help65_client.nsf/855dc7fcfd5fec9a85256b870069c0ab/e71745f2302f974385256dff00622436?OpenDocument
Subject: I don’t think your .FTSearch call is correct
I haven’t taken time to test this, but I’ve worked with FTSearch and I think that the following code:
Should be something like:
Set dc_forecast = db_forecast.FTSearch(“Form = ‘Forecast’ & FWorkNum = str_work_number”,0)
