Help with error: No engine configuration file - aborting!
I’m trying to consume a webservice using a Java Library. The WSDL imports fine but when I try to run code to use it I get the error:
lotus.domino.axis.ConfigurationException: No engine configuration file - aborting!
In searching around, it looks like I’m missing a client-config.wsdd file. A lot of people report this issue, but none give a solution?
Any help would be greatly appreciated!!
Thanks,
Kam
