Help with Easy Lotusscript?
The code below works great except it changes the status of document that i do the search for and not the current doc that is opened. The code is at the very bottom. Thanks ahead of time
Sub Click(Source As Button)
Dim response As String
Dim db As NotesDatabase
Dim searchDB As NotesDatabase
Dim searchDBName As String
Dim searchView As notesView
Dim searchDoc As NotesDocument
Dim proDoc As notesdocument
Dim doc As NotesDocument
Dim view As NotesView
Dim selection As String
Dim user1 As Variant
Set doc=db.CreateDocument()
user1 = doc.curAuthor
	'user1= source1.FieldGetText( "curAuthor" )
key =  user1
Set view = db.GetView("(Profile Document)")
Set doc = view.GetDocumentByKey (key )
Dim item As NotesItem
Set item = doc.GetFirstItem( "phone_st" )
If ( item Is Nothing ) Then
	Print "no phone item found"
Else
	Dim phone As Variant
	phone = doc.GetItemValue( "phone_st" )
	Call doc.ReplaceItemValue( "phone_st", "On Phone" )
	Call doc.Save( False, True )
	Call ws.ViewRefresh
Call ws.EditDocument( True )
Set doc = db.CreateDocument
Dim Change As Variant
Change = doc.GetItemValue( "Status" )
Call doc.ReplaceItemValue( "Status", "In Progess" )
Subject: Help with Easy Lotusscript ?
The bottom shows that you are creating a new document called ‘doc’. Which overrides the previous doc being set. So, in the bottom section, just call it newdoc, or something else.
Subject: RE: Help with Easy Lotusscript ?
I changed the bottom to newdoc and having the same problem.Sub Click(Source As Button)
key =  user1
Else
	Call ws.ViewRefresh
Dim newdoc As NotesDocument
Set newdoc = db.CreateDocument
Change = newdoc.GetItemValue( "Status" )
Call newdoc.ReplaceItemValue( "Status", "In Progess" )
Call newdoc.Save( False, True )
If you want to update the Current Document, that is open in the UI, use the NotesUIWorkspace CurrentDocument Property to get the document, and update it. You will probably want to use the refresh method of the NotesUIDocument to refresh it on the screen.
In your code it would be something like:
Set CurrentUIDoc = ws.CurrentDocument
Set CurrentDoc = CurrentUIDoc.Document
Change = CurrentDoc.GetItemValue( “Status” )
Call CurrentDoc.ReplaceItemValue( “Status”, “In Progress” )
Call CurrentUIDoc.Refresh
You are wanting to change the status of the existing document, not the new one, so change the status on doc. not on newdoc.
Ok i did that and i get the same result.
Set newdoc=db.CreateDocument()
user1 = newdoc.curAuthor
key =  user1
Set newdoc = view.GetDocumentByKey (key )
Set item = newdoc.GetFirstItem( "phone_st" )
Else
	phone = newdoc.GetItemValue( "phone_st" )
	Call newdoc.ReplaceItemValue( "phone_st", "On Phone" )
	Call ws.ViewRefresh
