Hello All,
I am trying to use the following code to make changes to design elements using DXL…
Set importer = session.CreateDXLImporter(stream, dbcurrent)
importer.DesignImportOption = DXLIMPORTOPTION_REPLACE_ELSE_IGNORE
Call importer.Process
I first exported the database using the DXLExporter class and then made some changes to a text that can be found on both forms as well as agents…
While the forms are getting updated with the new text…the agents are just not being processed…
Is there something I am missing…
Appreciate any help.
Arun
