Help with DXLImporter
Hi, I am using some sample code to generate an action hotspot in a richtext field using DXLimporter.
Here’s my code -
’ Build the DXL document including the hotspot in the Rich Text field
stream.WriteText{<?xml version="1.0" encoding="utf-8" ?>
 <item name='Display'>
  <richtext>
   <par>
The following MWG Policy Manuals exist:
MWG Quality Assurance Manual
Use “Navigation”
Sub Click(Source As Button) Call LaunchWorkspaceDocument(“MWGQuality”) End Sub
  </richtext>
 </item>
The hotspot is getting created correctly, but the problem is that the Lotusscript code that goes in the hotspot is being put in the Declarations section instead of OPtions and Sub Click event as specified in the above code.
What am i doing wrong?
Thanks.
Subject: Try this…
Introduce some white space around your LS code, e.g. change this
to this
REM Call LaunchWorkspaceDocument("MWGQuality")
I think that perhaps the way that we assemble the LS code together is getting confused without the extra white space. Not sure though.
Subject: Help with DXLImporter
I don’t have an answer for you, but I’m curious as to how this works in its entirety - I’ve never worked with DXLImport before, so I copied your code and tried to add it to a sample from the Designer Help, but I keep getting an error about unexpected string constant.
Would you mind posting your entire agent code?
Subject: RE: Help with DXLImporter
Here’s the complete code for the function
Function CreateNewHotspot(s As NotesSession, ws As NotesUIWorkspace, this_db As NotesDatabase, strDBTitle As String) As NotesDocument
' Purpose: Build a document using DXL and import into the current database and return the new document
On Error Goto ErrorHandler
Set stream = s.CreateStream
’ Build the DXL document including the button in the Rich Text field
Use “Navigation”
’ Import new document with button into current database
Set dmp = s.CreateDXLImporter(stream, this_db)
dmp.DocumentImportOption = DXLIMPORTOPTION_CREATE
dmp.Process
’ Get the NoteID of the newly created document
tmpNoteID = dmp.GetFirstImportedNoteID( )
’ Get the document by the NoteID and return it
Set newdoc = this_db.GetDocumentByID(tmpNoteID)
If Not (newdoc Is Nothing) Then
	Set CreateNewHotspot = newdoc
Else
	Messagebox "New document could not be found.", 0, "ERROR"
Exit Function
ErrorHandler:
’ If there’s a problem processing the DXL, you will be prompted with the Row and Column
Msgbox dmp.Log
Print Lsi_info(2) + " - Error #" & Format$(Err) & " at line " & Format$(Erl) & ": " & Error$
Messagebox Lsi_info(2) + " - Error #" & Format$(Err) & " at line " & Format$(Erl) & ": " & Error$, 0, "Error"
Exit Function
End Function
Just call this function from the agent.
Anyone have any idea about my issue? Help needed!
