I have a user that I moved his mailfile with adminp to userold.nsf, well I have since renamed the file back tio user.nsf and mail being sent to this user just sits in the mail.box waiting to be delivered to mail/userold.nsf. I have checked all names.nsf replicas in our domain and they all point to mail/user.nsf, yet mail still tries to go to mail/userold.nsf. I have done a CRTL-SHIFT-F9 on the directory incase indexes were corrupt to no avail. I am out of things to try… ideas anyone?
Try doing a “tell router update config” I’ve seen this issue before, and once you run the update config on the router, and then issue a “route *”, it usually works.
OK, we found the problem. It happened that somehow the AdminP process didn’t complete the move properly and left a NewMailFile field in the person doc with the entry of mail/userold.nsf. We removed that field and mail started flowing!
