Ii have a form for our Help Desk to use to change someones HTTPPassword in the NAB. The form runs on a notes client, it lets the user choose the person from the address book, checks to see if they have iNotes access through a role in the ACL, if the Role is enabled a password box and a change button appears. When the change button is pressed, it gets the encrypted value in the password and uses replaceitemvalue to change the internet password in the person doc. If I turn on the lotusscript debugger it shows the item being replaced but the field never changes. I am running simialiar scripts and I do not have this problem. What am I missing here? I am sure it is something very simple.
Set session = New Notessession
' Gets the current document
Set curdoc = session.DocumentContext
' Gets the primary address book
Set dbNames = session.GetDatabase("namail01","names.nsf")
' Gets the hidden view of person documents
Set viewNames = dbNames.GetView("($VIMPeople)")
' Gets the person document for the user
Set docNames = viewNames.GetDocumentByKey(curdoc.GetItemValue("UserName")(0))
If docNames Is Nothing Then
Msgbox "Error in Name Lookup"
Exit Sub
igrp = curdoc.GetItemValue("confirm")(0)
If igrp="The user is a member of the iNotes Group" Then
' Gets the new password entered by user
newPassword = curdoc.GetItemValue("NewPassword")(0)
' Gets the encoded password stored in user's person document
passwordInAddressBook = docNames.HTTPPassword(0)
' Gets the encoded form of the new password
temp = Evaluate({@Password(NewPassword)}, curdoc)
encodedNewPassword = temp(0)
' Updates the person document
docNames.HTTPPassword =encodedNewPassword
Call docNames.Save(True, False)
Msgbox"The Internet password has been changed "
Else
If igrp="Error in Name Lookup" Then
Else
If igrp="The user is not a member of the iNotes Group" Then
Msgbox "The user is not a member of the iNotes group, password change failed"
This sets the HTTPPassword item value when viewed in the debugger but does not change the person doc when completed.
Thanks for any input!
This exact script works if I do not change the HTTPPassword field!!!
