Help...Using a >= date to determine data for view column
I am trying to create a view that only brings back forms (named DefTicket) created after a certain date field (DateCreated) located on the form.
SELECT Form = “DefTicket” & ParentType!=“Converted to Child” & DateCreated >= 06/01/2007
I am using the code from above, but I am not getting any results back in the view. Any help would be appreciated!
Subject: Help…Using a >= date to determine data for view column
Hi Kelli,Try putting.
SELECT Form = “DefTicket” & ParentType!=“Converted to Child” & DateCreated >= [06/01/2007]
Subject: put date value within square brackets
Regards
Byju Joy
Subject: RE: put date value within square brackets
Thank you all so much, that seemed to do the trick!
Hi Kelly,try to use the simple action for creating complex view selection and once you create , change it to formula, so all the code is ready in the formula without any possible error.
