Hi
After finally completing our CRM-Database it was time for local replica testing, offline!. We found that after replicating and trying to access a document trough the mainView we encounter an error message every time:
“The replica of this database on the master lock server [servername] is not available. Would you like to continue? If you hit OK, you will be notified of any replication or save conflicts that occur”
As far as I can tell this occurs because of “document locking” issues. And correctly we have had “document locking” enabled earlier in the process but had decided to disable it (and ran a procedure that should unlock all documents).
What can I do to prevent this message !?!
Hope you can help ![]()
