Help to creat document in View?
Set doc = view.GetLastDocument Do Until doc Is Nothing
		doc.Sent=count
		doc.NBPath=szFileName
		Call doc.Save(True,True)
		Set doc = view.GetNextDocument( doc )
	Loop
with these codes I just update new status of the document in view. But I want to creat a new document listed in view while the last document still the same. Tks!!!
Subject: Help to creat document in View???
Dont get confused by View and Document.
Document is something that is composed by using a form.
View is just the representation of that document.
So create a New Document with the Form you would like to. Also make sure that view selection formula allows that document to be displayed in the view.
Hope this Helps.
Subject: RE: Help to creat document in View???
Yeh I know that but I want to creat a new document with the Form by script not by command
