Help ,sorry being dense - need to open a view using whole window
We’re opening a view in another window:
@Command([OpenView];“ROFSN”;@Name([CN];@UserName);1);
@SetViewInfo([SetViewFilter];@Name([CN];@UserName)+" Red";“ROFSN”;1;1)
What I have been asked to do is have that filtered view open up using the whole window, no sneaky list of views in the database. I’m being dense because I cannot see how to do it.
Any tips/suggestions gratefully received.
Subject: Hmmmm, a workaround
Hi again Sue,
You could create a Frameset with one frame, with your view as the content, then use:
@Command([OpenFrameset]; “”)
I haven’t tried it, and I suspect that getting to the right document might be tricky. Perhaps a PostOpen event in the view might do it? Also, your filter will complicate things too. Good luck!
Phil
