Help pls. Running agent / Lotus Script in Domino
Hi all, I’m new to Domino Web but having 1.5years exp in Notes Client. In a web application, I just tried to run an agent using a button press. It won’t run. I realized the agent must be signed. So I changed the code to LotusScript in the same button.
 The button is not displayed in Internet Explorer. Its available in the form(Designer) and there is no hide-when. But when i used the Formula language (an @command) that button is visible. (Is it true - only the button is visible in Web if @Formula or Javascript is coded for that button?)
  I've to run some Lotus Script for that button press. Is that any other way? If i used agents, it must be signed. But am not the signer. Even a single Print "Hi" statement also not working in that form. Suggestions pls.
Regards,
Guna
Subject: Help pls. Running agent / Lotus Script in Domino
You can’t run LotusScript in an action button on the web. The only way to run LS is to use agents. If you only want to perform calculations in the web client then use Javascript instead.
Ben
