I have a Domino 6.0.0, whenever I login to this server with IE 6 SP1, the authentication process works, because I can see myself in the list of users. But, all applications treat me as anonymous. Whenever I show the @username on a form, I am anonymous.
I tried to update to 6.0.1, but without any success. I also have updated explorer to the last patch and tried from different platforms (w98 ie6 sp1, w2000 ie6 sp1, wXP ie6 sp1).
do you have cookies enabled? You when authenticate you will receive a cookie within in your browser. The cookie is persistant – it will be deleted when you close the browser(s) window.
I think your problem is there not on the server.
HTH - Cheers - Email is in my profile if you need it.
I have other two domino 6.00 servers and it works on all of them but this one. I’ve tried from different workstations, all of them with cookies enabled. The problem is not about the cookies… …anyway, thanks for the response… …any more ideas ??
