-- HELP -- Notes Client Will Not Open
Yesterday I was using Notes without any issues all day. During the day, I installed the newest version of MS Office along with Visio and MS Project on my laptop. Notes continued to work fine.
Last night I booted my laptop and attempted to open Notes. The client seemed to open partially and then the CPU spiked to 100% and stayed there and the client froze. Nothing inside the main frame of the client ever appears, it remains grey and then after it locks up, if I click inside the client anywhere, it goes solid white. I’ve left the client up for 20-30 minutes and the condition stays the same. Eventually the CPU usage does return to normal, but the client remains frozen.
I am able to open designer and the Admin client without problems, if that gives any clues.
I tried removing 6.5.3 and reinstalling without success. I’ve also fully removed Notes and put 6.5 back on and that has the same issue. I also removed all the MS Office components as well and they are still removed at the moment.
I am not sure how to get under the surface to see what is causing this problem, so I am hoping there may be some people here that have seen this before or have some troubleshooting suggestions.
Thanks to anyone who can help.
Subject: – HELP – Notes Client Will Not Open
I’ve got the client working again and here is how I beleive I was able to fix it.
Opened the Admin client and chose to work on the local server (My PC).
Went to the ‘Files’ section of the Admin client and located my mail file (in the \mail subdirectory).
Right clicked the file and chose various options to optimize the file and repair it.
I am not sure which speific option fixed the issue, but I was able to open the file from within the Admin client and then was able to open it in my normal notes client.
Hopefully this will help others who encounter something similar.
