HELP! No eligible servers found. with Replica!
Hi,I have the following message on the Domino console, I wasn’t able to find anything related to this error message.
Is anyone able to help me and find a solution to this.
Many Thanks.
Nico
Unable to replicate with server No eligible servers found.: Unable to find path to server. To trace this connection, use File - Preferences - User Preferences - Ports - Trace (Notes client) or Trace command (Domino server)
Subject: HELP! No eligible servers found. with Replica!
Do have a valid connection document? What happens when you do a Trace?
check DNS.Can you ping server by the same name as in your connection document?
Subject: RE: HELP! No eligible servers found. with Replica!
Connection and DNS are ok. Seems to be related with DDM, the error goes on even quitting the replica task, it disappears when quitting the event task!
